Creates or deletes a generic port-group name that can be associated with a list of ports.
| group | Named list of ports. |
| port_group | Port group name. |
| add | Add ports to port group. |
| delete | Delete ports from port group. |
| port_list | Specifies a port list. |
N/A.
Because port-groups may be configured for multiple applications, no check is done other than that the values entered are ports. Individual applications handle illegal actions on ports as necessary. QoS commands that use port groups are updated automatically if the ports group is removed or if ports are added or removed from the group.configure ports group testGroup add 1-5 configure ports testGroup delete 3
This command was first available in ExtremeXOS 16.1.
